New here, need to install new door speakers
Old Dec 24, 2011 | 12:38 PM
2007MonteCarloLS's Avatar
Default New here, need to install new door speakers
I hope this is the right place to ask how, ask some people how to help out with me installing new door speakers on my 2007 Monte Carlo LS. It seems a little difficult to get the door panel off. I took the two Phillips screws out, I also need to get a hex wrench or whatever it may be called and take the two other screws out that were holding it on, I need to find the tool for that. Once I get those two hex screws out, should the door panel pop off? Anything else I should know or do?
Old Dec 25, 2011 | 11:10 PM
NovaSS369's Avatar
once you remove the two torx bits under-neath the handle you will be able to pull the panel off as long as you removed the one behind the handle and the one by the tweeter.
Old Dec 27, 2011 | 09:11 AM
I was able to remove the four screws total but of course the panel is still connected, behind there, like the electric lock system and I am not sure what to do from here. Please help.
Old Dec 27, 2011 | 09:18 AM
Boxman420's Avatar
you have to go around the bottom and carefully pop off the bottom make take a little force. then the door panel will fall(with the electric components still connected). best to have someone else unplug everything while you hold the door.
Old Jan 2, 2012 | 04:29 PM
I have successfully popped the door panel off with the electrical stuff still connected, allowing me to see better behind it, letting the door panel rest at an angle, now I want to give an image link to the speakers I bought for the door and show you all what I am working with:
http://i69.photobucket.com/albums/i8...ng/Speaker.jpg
Can anyone out there tell me how to successfully install this on each door? You being Monte Carlo experts must know the speaker has the hole cover on the door, like a fishnet styling is the best way I could describe it, I of course do not want this any longer once I have my decorative skull speaker on there, I am just so clueless and do not really have anyone in person to help me out with this yet.
Robert-12-21
23
Nov 28, 2016 11:00 AM
thewhitestcarlouknow
21
Jul 10, 2009 09:05 PM
sws2000
Apr 28, 2008 03:37 PM
Bxbootlegger
Apr 12, 2008 09:02 PM
earthquake
Jan 14, 2005 06:20 PM
