new car stereo help needed
Old Nov 25, 2009 | 11:14 AM
tkatz14's Avatar
Default new car stereo help needed
ok guys (and gals) so i just bought a new stereo for my monte...i have the bracket ready and the wiring is pretty much done too. I have it wired to the point where it should be working...all power and speakers and remote wires..but i plugged it in and it has power, but no sound. i pulled a wiring diagram from mitchell and it is a mess. from what im gathering, all wires run through the amp in the trunk...can i keep that without by passing it? i.e. what wire turns the amp on (remote wire) any help is appreciated thanks
Old Nov 25, 2009 | 11:29 AM
are you amping all your speakers? and you got a wiring diagram from me? what? lol
Old Nov 25, 2009 | 11:57 AM
tony1379's Avatar
i know in my 2001 jimmy there was a wire that powerd the factory amp whch had to be hooked up for the sound to work with my aftermarket deck
Old Nov 25, 2009 | 03:46 PM
tkatz14's Avatar
im using the amp thats stock mounted in the trunk...it amplifies all 4 speakers and i want to leave it that way
do you remember what wire powers the amp up?
Old Nov 25, 2009 | 03:54 PM
im not sure if im understanding this right but ill try to help you out here lol
the power is straight off the battery, the ground is to the chassis
but if the amps just not turning on you need to run a remote wire, there should be a seperate wire for it, on my deck it was blue with a cap on it, then you can branch it off from amp to amp.
Old Nov 25, 2009 | 03:56 PM
oh just reread that, um, if you look on the wires of the harness itself, it should say on there, i think there's either 2 or 4 wires for it
Old Nov 26, 2009 | 10:50 AM
tkatz14's Avatar
there are two wires that are possibilities...there is a amp sensing that connects straight between the two...or there is a amp control that goes from the amp to a junction block and then comes back through the ant enable
Old Nov 26, 2009 | 10:45 PM
Dbl_D718's Avatar
Are you sure the amp isn't turning on? If you connected your speaker outputs on the aftermarket headunit to the stock amp's signal wires, it might be going into a potect mode because the speaker outputs on the headunit carry much more power than an amp's signal wire should.
Old Nov 28, 2009 | 08:10 PM
tkatz14's Avatar
well guys i got it worked out...i sucked it up and bought the stereo interface from walmart for $40...i soldered it all up and it looks and sounds great! thanks for the help
r00t
Apr 17, 2015 09:43 AM
SteveCZ28
Apr 2, 2015 09:04 PM
Hiroska
Nov 28, 2014 09:48 AM
01blackmonte
Jan 29, 2009 03:05 AM
