need help with a new system
Old May 13, 2010 | 09:04 AM
  #41
Originally Posted by monte793
ok thank you.
heres on that i found, he used a nut from a cover in the trunk (not a monte) but you can kind of see what he did, he pinched it there making a secure ground
Old May 13, 2010 | 11:18 AM
  #42
theeohiostate6's Avatar
from my experience a dynamated car is 10x better than a non. It makes it sound so much better/tight. On a side note if i have a crack in my cone on my W7 is it still usable? Also is there a fix for this?
Old May 13, 2010 | 11:44 AM
  #43
where in the cone is the crack? if its in the middle thats usually the dust cover and wont affect it, but anything else could effect the sound, you could glue it with light weight glue just to seal the crack
Old May 13, 2010 | 09:07 PM
  #44
04MonteLS's Avatar
Why can the ground wire only be 12 to 18 inches?
It's not that it can only be that long, it's that it's better if it's only that long because the longer the wire is the more susceptable it is to picking up resistance/interference in the chassis of your car which essentially makes it an antenna, the result of which is the noise you're hearing.
Originally Posted by trewyn15
lmao okay buddy, im not gonna argue with you, i was just putting in what happened from experience...
Ah, so I didn't add anything as I saw fit? Not that it was ever in question. It's clear which one of us knows what's up as far as car audio, no argument there!
it has to do with resistance, the less length you have, the less resistance you will have. so the longer the wire, the less voltage gets to the amp, because there is not a good full circuit, which can cause the amp to go into protect mode.
Is voltage carried across a ground wire? What's "a good full circuit"? Actually, nevermind, I don't even want to hear your answer.
where is a good location for the ground?
Anywhere to the chassis of the car and to bare metal.
you can put a screw directly into the body for a ground, or any bolts that are connected to the chassis, like seatbelt bolts, you just need to make sure its something without paint on it so it has a good connection to the steel
DO NOT GROUND YOUR EQUIPMENT TO THE BODY, GROUND IT TO THE CHASSIS! Please stop giving bad info.
I wanna add a little to the "grounding" issue. I never used somthing that was already in the car. I have ALWAYS drilled/tapped my own ground holes to make the wire as short as possible. And so I could always use a 4 gauge eye, just to make sure I have the best ground possible. No more from me on this.
That's very helpful and useful info there, that's what we need in this section...people who know what's up giving out good info!
True story! Sound deadening helps alot, it blocks alot of the road noise and lowers the resonance of your car as well as getting rid of rattles and stuff. It depends on where the crack is and how big it is. You have two options, you can either try glueing it using some CA glue or you can have your sub reconed where they basically replace all the soft parts of the sub as well as the voice coil leaving you with basically a brand new sub. www.fixmyspeaker.com is the best place i've found for recones, their customer service is top notch, David know's what he's doing and does it well!
Can you please show me the dust cap on a JL Audio W7 sub?
Old May 13, 2010 | 10:37 PM
  #45
the body is connected to the chassis, the dust cap is in the center, does it pop out? no, is it there? yet, if you were to pull it apart there is a center in it, and covering it is considered the dust cap, i love how you carefully read through and find the smallest things that are just out of line, even tho they still make sense, and point them out, trying to be an ***, ive tried to let it go til now, you need to lay off and stop acting like you know everything.
Old May 13, 2010 | 10:40 PM
  #46
iMSeRiOuS's Avatar
wtf is that LOL
that ground is horrible
that wire is too long
you need to scrap the paint of with sandpaper to the bare metal for your ground.
Old May 13, 2010 | 10:41 PM
  #47
All fixed magnet loudspeakers have a dustcap if they don't have a phase plug, whizzer cone or coaxial driver. As was said, the dustcap covers the hole cone to give a smooth concave look. Other examples are the RE Audio subs, Acoustic Elegance AV line and the Image Dynamics subs.
just throwin it out there big shot
Old May 13, 2010 | 10:42 PM
  #48
Originally Posted by iMSeRiOuS
wtf is that LOL
its a nut to the chassis, its not my car, and the wires a little over a foot
Old May 13, 2010 | 10:46 PM
  #49
iMSeRiOuS's Avatar
i know it isn't yours... but man LOL
that just looks really janky
Old May 13, 2010 | 10:48 PM
  #50
it was for a satellite radio antenna if i remember correctly, so it didnt need to be super great lol, i was just tryin to give him an idea of it
