6th Gen ('00-'05): Need help with double din aftermarket radio only powering on after battery reset
Old Mar 21, 2024 | 07:26 PM
Jeffreysmonte2003's Avatar
Default Need help with double din aftermarket radio only powering on after battery reset
stereo double din turns on and works when battery is just connected but not any other time periodically turns on while driving, any ideas? No fuses are blown and every time the battery gets unplugged and replugged it works just fine until the car is shut off, btw I do have an ignition cylinder and passlock issue occasionally because my key doesn't have the chip like the original key for it, I had a spare remake made cause I lost my keys out of town awhile back, could the passlock possibly be the culprit? Or is it most likely a wiring connection issue?
Old Mar 23, 2024 | 11:48 PM
nitehawkjcb's Avatar
Check the remote wire would be my first guess, then make sure the rest of the radio connections are correct.
02 Earnhardt Monte Carlo SS
Jan 21, 2015 09:59 PM
RasCricket
Aug 31, 2013 08:19 PM
djtiny
Jun 16, 2012 05:39 PM
Spiderman52781
Dec 1, 2007 01:04 AM
DFresh
Mar 2, 2007 10:14 PM
