6th Gen ('00-'05): Subwoofer question
The question is far too vague. What are you adding a sub for? What kind of music do you listen to? You say you've got the car ready for a sub, does that mean you've already run wiring, if so what Guage power? What is your budget?
If you're just starting out, your best bet is probably to go to a local audio shop and let them demo various setups in their demo room. Just keep in mind 2 things:
-They only carry certain brands so there is other stuff out there that may work better for you.
-The audio response in a big open room is nothing like it will be in your car. It'll just help you take the first step to seeing what you like.
I worked in car audio for about 3 years and had numerous sub setups in my monte:
-2x 10" bottom end Pioneers in a bandpass box with a Jensen amp
-Same subs mounted in the rear deck
-Changed to Earthquake dbx 12"s on a Directed 1100d first in a small sealed box, then to a custom made ported box
-Swapped the subs for 12" Hurricane Powerstrokes on an Earthquake D2 in a custom ported box.
-Swapped that setup for 2 12" Atomic ELE subs on the D2.
-Built a custom ported fiberglass box to replace the rear seats
-Went back to a large custom trunk ported box and upgraded to an Earthquake D3 amp.
But I was into dB competitions and listening to mostly electronic music and occasional hip hop. Someone who listens to rock and wants a more balanced setup would hate what I ended up with.
04MonteLS
09-03-2005 01:05 AM
