Maing my own sub box
#31
Your amp is rated stable at 1 ohm, so running it at 1 ohm won't hurt it at all. It's power will just be the same as at 2 ohms for this amp though. Also, three 4 ohm subs wired in parallel will give you 1.3 ohms, just fyi.
#32
Yeah, your amp is 1 ohm stable so it shouldn't be a problem at all, it will do over 900 watts rms @ 1 ohm, although they don't say exactly how much over. But the box you'd need to build will be a little bigger than I thought....if you're gonna keep it sealed you'd need a box with 3.75 cu. ft. internal volume after displacement. That's a pretty nice size box for our Monte's...my current box is 4 cubes, i'm trying to get some subs that will allow me to have a smaller box but it's not looking like i'm going to achieve that goal since I'll be picking up some DD 2512's here pretty soon.
#34
http://my.kenwood.com/Car_Entertainm...iers/KAC-9103D
#36
Yeah, I wonder why they're being so vague about it. Kinda funny they'd choose to handle it that way cause they list a peak wattage as 1800 watts, although i'm sure that's at 16v, maxed out for .5841279643521478 seconds.
