low volume on radio
Old Nov 14, 2013 | 10:03 AM
sundance12198's Avatar
Default low volume on radio
just recently my radio got to the point that I have to turn the volume almost all the way up to listen to it. any idea what may be the problem? its a 2004 monte carlo ss
Old Nov 14, 2013 | 10:19 AM
Hiroska's Avatar
More info required...is it stock radio? Aftermarket, Got any subs? Any electrical problems you noticed?
Old Nov 14, 2013 | 12:07 PM
JC Colon's Avatar
Without more info on your system, aftermarket Or Factory, I would say you have a bad amp!
Old Nov 15, 2013 | 06:55 AM
no electrical problems and no subs.. stock radio from factory
Old Nov 15, 2013 | 07:31 AM
Hiroska's Avatar
Then its time you added some. Your factory amp is going out. its not producing what it should be putting out. Just get a aftermarket amp and youll be set.
Old Nov 23, 2020 | 07:09 PM
Ronnie Jr.'s Avatar
Default Low volume
What if you have the factory radio and amp and replaced the factory amp and fuses?.
Old Jan 14, 2021 | 01:54 PM
tomcarloguy's Avatar
having the same issue here with my recent acquisition. Started looking into replacing the amp.
Murray137
Nov 23, 2013 10:54 PM
montess2k4
Mar 3, 2013 08:12 PM
kdubb72
Jul 6, 2010 12:28 AM
ej19880
Jul 4, 2010 06:44 PM
sportjunkee
Jan 13, 2008 06:18 PM
