Low tire pressure?
I put a 7 in flip out cd player/dvd in my monte carlo and the low tire pressure light is on. I took it up to the dealership but they said that they could not do anything because the factory radio isn't in their. they said that it wouldn't go out as long as I have an after market radio in. what should I do? how can I fix this problem?
This is really simple and can be found in the ownership manual - the dealer should know this.
Just pull the headlight *** out one click and push it back in 3 times in about 2 seconds. You will hear a beep and the light will go off.
Tire Pressure Monitor Procedure
Using the exterior lamp switch
-Adjust all tire pressures to the recommended kPa/psi. Refer to Tire Inflation Pressure Specifications in Maintenance and Lubrication, or to Tire Placard in General Information.
-Turn ON the ignition, with the engine OFF.
-Cycle the exterior lamp switch from OFF to parking lamps 3times within 5seconds.
Important: It may take up to 30 minutes of straight line driving for the computer to learn the tire pressures.
montejass
FWD Tech Guides '95-'07
42
Sep 22, 2021 10:19 AM
