Looking to buy new head unit, back speakers and amp.
Old 01-28-2010, 07:36 AM
jaws2008's Avatar
GOT SPL
For the rear 6x9 try these
http://www.dealercostcaraudio.com/spr-69c.aspx
or this
http://www.dealercostcaraudio.com/jlaudioc2-690tx.aspx
i recommend components in the front 6.5" try these
http://www.dealercostcaraudio.com/alpinespr-17s.aspx
or this
http://www.dealercostcaraudio.com/jlaudiovr650-csi.aspx
for the head unit not sure how much you want to spend on it but for about what u looked for earlier try this
http://www.dealercostcaraudio.com/cda-9884.aspx
I had the 9886 model b4 and i liked it so i would upgrade if you can instead of the 9884 i posted link to above. for a good touch screen player your going to have to spend at least 500 to 600 on it...I would recommend a kenwood screen, i feel they give you the most "bang for your buck"
For a subwoofer amp...im going to assume you want 1000W rms power...try these
http://www.dealercostcaraudio.com/MRP-M1000.aspx
or this
http://www.dealercostcaraudio.com/ro...09edition.aspx
Old 01-28-2010, 08:59 AM
Deadsnake's Avatar
I want a head unit that has a USB plug aswell, as for the amp I just need one for my subwoofer, I have one for the speakers.
Old 01-28-2010, 10:21 AM
I know the Pioneer headunit has a USB plug, and I'm pretty sure the Alpine does as well.
As for sub amps, we really need to know what type of subs you have, how many you have, and what their voice coil configuration is to make usefull recomendations.
Old 01-28-2010, 10:32 AM
Deadsnake's Avatar
http://www.oem-auto-parts.com/servle...12D-Car/Detail
those are it
Max power handling 1100 watts
RMS power handling 600 watts
Sensitivity 89dB
Frequency Response 25-200Hz
Impedance 4 Ohms
Height 18.5"
Width 29"
Depth 16.5"
Features
• Low-Q optimized drivers
• Carpeted enclosure
• Plexi subwoofer viewing windows
• Built-in crossovers
• Mirrored chambers
• 12v DC blue glow illumination
• 4" Port dual chamber design
• Easy add-on to existing systems
• Impedance: 4 Ohms
Old 01-28-2010, 10:44 AM
Do you already have those? I'll assume it means the whole enlosure is 4 ohms, not 4 ohms per sub. If it's 4 ohms total, this amp bridged would be a good choice.
http://www.powermaxelectronics.com/p...&idcategory=10
Old 01-28-2010, 10:58 AM
Deadsnake's Avatar
Yes I have had those for awhile.
Old 01-28-2010, 10:59 AM
Deadsnake's Avatar
Any other amps? And what other wiring would I need?
Old 01-28-2010, 12:02 PM
jaws2008's Avatar
GOT SPL
What wire do u already have...to hook up subs to an amp...i would run RCAs off the headunit to the amp...the amp needs power and ground i would recommend a 4AWG wire..a remote cable to run from headunit to amp so the amp is on only when headunit is...and finally the speaker wire from amp to subs.
Dont forget a fuse directly after hooking power up from battery.
Old 01-28-2010, 12:24 PM
Deadsnake's Avatar
How much would those wires cost me?
Old 01-28-2010, 02:11 PM
jaws2008's Avatar
GOT SPL
this kit gives you everything you need to set up the amp for your subs
http://www.dealercostcaraudio.com/RFK4X.aspx
Quick Reply: Looking to buy new head unit, back speakers and amp.
