LED step lights?
Old Sep 9, 2009 | 03:25 PM
03Monte's Avatar
i would love to switch over as many light to LED as i can, how do i know what part will work in my car?
Old Sep 9, 2009 | 03:28 PM
you go by bulb number, each LED has an equivalent number that they use.
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3457ALL
Front Turn Signal Light Bulb Size: 3457ALL
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 194
Rear Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 194
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 194
Dome Light Bulb Size: 578
Step/Courtesy Light Bulb Size: 194
Trunk/Cargo Area Light Bulb Size: 912
Old Sep 9, 2009 | 03:32 PM
03Monte's Avatar
wooo, good info here!
are some of these spots better left alone?
Old Sep 9, 2009 | 03:35 PM
Use your judgement. Obviously don't change headlights and stuff.
Mostly you'll just buy a bunch of 194s and the dome light 578.
Old Sep 10, 2009 | 03:40 AM
Pure2sin's Avatar
Well I turned the light around and it will not work that way? I do not get why all the LEDs will not light up. Like I said when plugged into the map lights all the LEDs light up but in the under the dash step lights only the center one lights up. I would like to know if anyone else who has put LEDs in the step lights has had this issue?
Old Sep 10, 2009 | 05:18 AM
...Thanks everyone for helping a member, and taking the time to research & post : ) I appreciate 4-Sure Thank You!!!
Old Sep 10, 2009 | 08:40 AM
I have LEDs in my step-lights and I'm not running any issues with it.
Old Sep 10, 2009 | 11:49 AM
RickAKATed10's Avatar
Photobucket
Ditto.
Old Sep 24, 2009 | 12:22 AM
Pure2sin's Avatar
What kind of LEDs are you running? I have been RACKING my brain trying to figure this out. Checked the fuses the wiring and nothing yet. I just can only get that center LED out of the seven to light up so its basically I paid for a 7 LED bulb that is only lighting up with 1 LED.
Old Sep 24, 2009 | 08:05 AM
I bought a 7-LED 194 Red bulb from V-Leds.com
KingOf206
Dec 25, 2013 07:12 AM
deeboe
May 19, 2010 09:58 PM
Frosty LS1
Apr 16, 2010 07:46 PM
Nocturnx
Jan 18, 2008 10:00 AM
