LED Bulbs
LED Bulbs
I am looking into changing the taillight bulbs on my 04 Monte to LED (not the whole housing, just the bulbs) I'm going to smoke color the stock lenses, does anyone have an experience with these, are any brighter than reg. incandescent bulbs, I've seen some reg. bulbs that claim to be brighter and have a silverish coating to the bulb but they were just B/S, some of the 3057 LED bulbs seem to be very expensive, anyone know if they are any good/brighter?
Aaron
Aaron
..Hi Aaron, Good 2 C U online. There are many bulb's 2 choose from. Check out our MCF Search & Googles search
for more infor. Check back also 4 member's post on your subject. Good Luck from `Space
Tail Light
3157
Replacement automotive light bulbs for 2004 CHEVY CHEVROLET Monte Carlo
Newest light bulb upgrades for your CHEVY CHEVROLET Monte Carlo. Super high intensity and super bright light bulbs that give you more then 150% light output. Easy plug and play automotive car replacement bulb delivery to your doorstep.
Light bulb application available for 2004 CHEVY CHEVROLET Monte Carlo headlight (high and low beam), fog light bulb replacement, parking light, signal, corner, dome, tail light bulbs, and more. Please select your correct year and model below for available light bulb. We carry top brands like Piaa, Nokya, Sun Auto, KYO, California Sunshine, Koito, Polarg, SPW, and more. If you do not see the application for your vehicle please contact us.
Tail Light
3157
Aaron -
After seeing an Intimidator that had all of the interior light replaced with proper LED's....
All I can say is....wow.
It did look really good.
I've always kinda shied away from anything LED related because it's a little too "ricerish" for me, but this car just had all of the stock bulbs swapped out with LED's, which gave it a super clean interior looks.
Go for it man. I've been meaning to, but it's pretty low on my list of priorities right now. Besides, I didn't want that guy to think I was biting his style.
-Riggs
-Riggs
http://www.v-leds.com/
you can find some good stuff on here led wise decently priced I replaced my dome and both driver and passenger lights have multiple different set ups wedge multi led bulb led panel led about everything you can need
this is the 921 if you use a 921 for your reverse these are in white have multi color but I think anything other then white is illegal at least here in ks
http://www.v-leds.com/921-LED/White-...orLanding/true
but I will warn when i installed more then 3 Led's i aslo had a issue where when i replaced the map lights Dome,foot wells both passenger and driver would stay on could never figure out why when i had all 5 plugged in they would stay on even when car was turned off weird !! so beware if installing more then a couple might run into issues hope i didnt ramble and hope this helps a lil take care
KingOf206
12-25-2013 07:12 AM
