Interior Speakers
Old May 19, 2012 | 05:05 PM
Bait's Avatar
For now I am keeping it. I will add most likely at tax time next year.
Old May 19, 2012 | 09:13 PM
wait until you swap it out until you do anything then, that's what I'd do
Old May 19, 2012 | 11:30 PM
Milhouse's Avatar
@Bait - No need to wait to add the amp until you get the head unit. Your amp will work more efficiently and the SQ will be better once you do get the new head unit due to the increased signal strength but until tax time next year you can still do the upgrade and be happy.
Old May 19, 2012 | 11:51 PM
Unless he doesn't want to bypass the factory amp to get the signals, just asking for more of a pain and spending money/time to get signal to the new amp when all he'd have to do is run RCAs when he gets the new headunit.
Also, if you really want to chose that route, don't get the bypass plug, bypass it on your own, wire the wires together, that's all the plug does, save yourself $30-50.
Old May 20, 2012 | 09:32 AM
Bait's Avatar
I do have a PAC SNI-35.
Old May 20, 2012 | 09:46 AM
Milhouse's Avatar
Bypassing the amp is as difficult as this, unplug the connector from the amp, insert bypass connector, done. Takes all of 5 seconds. The bypass plug can be had all day online for less than $10 so i'm not sure how he'd by saving himself $30-$50 if he were to do it himself, which would
a.) Cost him more than buying one if he were to buy the large connector, contacts and wires needed, not to mention a soldering iron and solder to complete the job if he doesn't already have one.
b.) Be a more permanent solution resulting in modification of the original wiring harness.
c.) Take incredibly more time and cause way more stress during the process.
Getting signal to the new amp is as simple as connecting both rear speakers to a LOC and running rca's from the LOC to the amp. which would set him back a whopping $10<---click me and since he's gonna have to run rca's from the aftermarket deck when he gets it he might as well get the one's he's gonna need then, now.
**Edit**
Since he's already got the LOC, he'd only be spending $10-$15 for the bypass plug (including shipping).
Bait, I say go for it! The only reason not to go for it is if your intention is competing and being competitive in an SQ competition. Other than that bro, nobody is gonna get in your car and take a listen and go "wow man, you must have a LOC hooked up, that sounds horrible!" It'll sound significantly better than you current setup and will hold you over until you can upgrade your deck, once you get your deck you'll have more control over the sound, will have a stronger signal going to your amp and can reset your gain on your amp (resulting in a lower gain setting) due to the much better signal it's getting.
Old May 20, 2012 | 05:40 PM
Bait's Avatar
I do feel
Old May 20, 2012 | 05:57 PM
Originally Posted by Bait
I do feel
I'd say it stayed pretty on topic with the first post, the OP never posted back, although all of this information could have been found using the search function tho lol
01MoneyCarloSS
14
Sep 6, 2012 08:06 PM
blackmonte781
Mar 3, 2011 08:35 PM
novagenesis300
Jan 31, 2011 10:31 AM
04MonteLS
Aug 13, 2005 03:14 AM
earthquake
Jan 14, 2005 06:20 PM
