6th Gen ('00-'05): interior paint
Old Feb 4, 2014 | 02:21 PM
soaxin's Avatar
Default interior paint
What is the best way to paint the door pannels? I'm converting my interior from Grey to black.
Old Feb 9, 2014 | 03:38 PM
owens91's Avatar
there are a few members here including myself that painted the door panels. the best way to do it is remove the door panels clean them and and prime paint then paint them. if u take a look at a few members you might get some ideas, i got mines off turbo monte's door panels
Old Apr 18, 2014 | 02:44 AM
M.SEA's Avatar
Ive got some pics up of mine. I pulled my doors and my entire dash and painted them piece by piece
1st step is sand. 80 grit or so to get rid of the texture and make sure the primer sticks. 2 maybe 3 coats with sanding between each coat. Wipe lightly with lacquer thinner to remove all the dust and then spray again.
Once your primer is smooth, then comes your color coat
Once again sanding between each coat. 3-5 coats depending on how much you want, 220 grit, all the way up to 1500 and 2000 grit
Rl350ss
Apr 15, 2013 01:21 AM
LoudBlazer
Sep 7, 2009 11:27 PM
red03ssmonte
Mar 28, 2009 02:23 PM
mickey
May 14, 2005 08:21 PM
big green dog
May 2, 2005 02:33 PM
