I need some help
Old Mar 5, 2012 | 03:38 PM
vinceb's Avatar
Default I need some help
I have a 2007 monte carlo LS, and the turn signals work but they don't make (for lack of a better term) the tick tock noise and also when locking the car from the inside it used to chime and it recently stopped doing that. If you listen really close you can still hear each sound but it is very faint. I went through the DIC and both sounds are set to their max level and still nothing comes out. I read someplace that these sounds were tied into the radio fuse so I replaced the fuse to no success. I am out of ideas any help would be great thank you.
Old Mar 5, 2012 | 03:44 PM
If you open the door with the keys in the ignition, is that chime also gone?
Check to make sure your driver's door speaker is working.
Old Mar 5, 2012 | 04:15 PM
vinceb's Avatar
I know for sure the speaker is not working.
Old Mar 5, 2012 | 04:31 PM
Ashley.Marie's Avatar
When my BCM was going bad from my remote start my car did the same thing and it wouldn't honk when I locked it, maybe a check on that?
-Ash
Old Mar 5, 2012 | 04:58 PM
My 07 doesn't make the tic toc sound. It is just quiet.
Old Mar 5, 2012 | 05:28 PM
Well the chiming goes through the speaker... so... probably why you can't hear anything.
Old Mar 6, 2012 | 10:32 AM
ratbuddy's Avatar
Turn signal in my 06 is super quiet too, it's kind of annoying.
MCSS06
May 29, 2015 08:04 AM
blackmonte781
Oct 3, 2011 01:38 PM
nebstewart07
Jun 19, 2009 08:38 AM
mickey
Aug 23, 2006 05:31 PM
Puppet Master
Aug 15, 2006 07:44 PM
