View Poll Results: Do you want a write up?
Yes!
50.00%
No.
0%
Whats a parallel circuit? (interested)
50.00%
Voters: 4. You may not vote on this poll
How to wire a parralel quick connect circuit write up poll
Old Oct 16, 2013 | 11:17 PM
dbaldwin's Avatar
Default How to wire a parralel quick connect circuit write up poll
Hey all, I'm currently working on creating a professional grade quick disconnect system to wire 1 or more devices to switches embedded in your center console off of a 12VDC grounded and safed parallel circuit. I know how difficult electronics seem to alot of people (and how they did to me before I really learned about them) And if you buy devices for your car its tempting to just plug it into the battery and run it straight wire. This can be very unsafe and not to mention silly looking if you want to run several devices (say three lighting systems, a couple subs and an electric exhaust cutout on the same car). I was wondering if anyone was interested in a write up to show you how to do this safely, cost effectively, and best of all NO SOLDERING. (dont get me wrong i love it, but its not for ametures in a car with many flammable things) and hopefully you can learn a little about electronics along the way. I just want to know i people are interested so i can start taking pics before i get in the groove and bust the whole thing out. If anyone seems interested ill definitely do the write up.
Old Oct 17, 2013 | 12:24 AM
I wouldn't mind seeing how you do it, or how others do it to compared to how I wire up switches in my car.
Old Oct 17, 2013 | 11:10 PM
dbaldwin's Avatar
Well than Crazyzach ill do it just for you! Maybe someone in the future will find it useful. The switches arrive on the 23rd (amazon slow shipping)
Old Oct 18, 2013 | 06:57 AM
03SSLE's Avatar
Run a (fused) large gauge feed line from the battery into the passenger compartment to a power distribution block. Run (fused) individual circuits to each device from there. Problem solved.
Old Oct 18, 2013 | 08:43 AM
KCFITZ78's Avatar
I agree with 03SSLE.... run the correct gauge power feed to a fuse block.
Old Oct 18, 2013 | 08:52 AM
dbaldwin's Avatar
The point was to avoid soldering and difficult connections. And also make the whole thing quick disconectable. Gotta fuse the line right off the bat.
Old Oct 18, 2013 | 09:01 AM
KCFITZ78's Avatar
No soldering is required with that type of fuse block.... just crimp connectors onto the wires and insert into back of fuse block.
Old Oct 18, 2013 | 09:35 AM
dbaldwin's Avatar
I looked at a fuse block couldn't find one like that. I'm going to use some pretty basic stuff you can find in automotive stores. Does it let one input be split into multiple outputs? That's my main goal.
Old Oct 18, 2013 | 10:31 AM
03SSLE's Avatar
Yes, that is the purpose of a distribution block/ fuse panel. It is fed by a (fused) large gauge wire from the battery. From there you can create several individual (fused) circuits.
Old Oct 18, 2013 | 10:38 AM
dbaldwin's Avatar
Iv only seen that kind of fuse block thats a lot more intricate. Couldnt find a simple one like that. Used ring splices and screws to make my splitter (haha mechanic) might incorperate one of thoes later If I can find it. Basically making my own non solid one with spade splices.
