How to wire a parralel quick connect circuit write up poll
Hey all, I'm currently working on creating a professional grade quick disconnect system to wire 1 or more devices to switches embedded in your center console off of a 12VDC grounded and safed parallel circuit. I know how difficult electronics seem to alot of people (and how they did to me before I really learned about them) And if you buy devices for your car its tempting to just plug it into the battery and run it straight wire. This can be very unsafe and not to mention silly looking if you want to run several devices (say three lighting systems, a couple subs and an electric exhaust cutout on the same car). I was wondering if anyone was interested in a write up to show you how to do this safely, cost effectively, and best of all NO SOLDERING. (dont get me wrong i love it, but its not for ametures in a car with many flammable things) and hopefully you can learn a little about electronics along the way. I just want to know i people are interested so i can start taking pics before i get in the groove and bust the whole thing out. If anyone seems interested ill definitely do the write up.
I wouldn't mind seeing how you do it, or how others do it to compared to how I wire up switches in my car.
(Post 576936)
(Post 576936)
Originally Posted by 03SSLE
(Post 577092)
Run a (fused) large gauge feed line from the battery into the passenger compartment to a power distribution block. Run (fused) individual circuits to each device from there. Problem solved.
I agree with 03SSLE.... run the correct gauge power feed to a fuse block. http://www.delcity.net/images/photos/73805_primary.jpg http://www.delcity.net/images/photos...20_primary.jpg |
Originally Posted by KCFITZ78
(Post 577116)
I agree with 03SSLE.... run the correct gauge power feed to a fuse block. |
No soldering is required with that type of fuse block.... just crimp connectors onto the wires and insert into back of fuse block.
(Post 577123)
Originally Posted by dbaldwin
(Post 577132)
Does it let one input be split into multiple outputs? That's my main goal.
(Post 577152)
Yes, that is the purpose of a distribution block/ fuse panel. It is fed by a (fused) large gauge wire from the battery. From there you can create several individual (fused) circuits. |
