How Low Does Your Door Panel Hang?
So I got my MC used from a dealer and one of the things I noticed after a month or so was the driver side panel doen't match up with the dash. I took it back 3 times to have them fix it but it's still the same, finally I point out where the issue is and the body shop tells me that's just how it is. My salesman says there's no other MCs on the lot for him to compare it to so he can't really tell the body shop to do anything...so now I turn to my MCF friends. How does your driver's side dash look?
Driver Side 1
Driver Side 2
Compared to Passenger Side
Driver Side 1
Driver Side 2
to me it looks like ur passenger side gap is too tight
i just went out to check mine right now and the gap is about 3/8 on both sides, looks just like ur driver's side
ur right miller, i think it's his passenger side lol :p
I agree with the 3/8th inch estimate, but I am going to say that both gaps on your vehicle are off. Mine have about a 3/8th of an inch gap on both sides. To me, it looks like your driver side is too far and the passenger side is too close. It may just be the plastic cover on your A-Pillar. I know the heat last summer wreaked havoc on my interior. I even had to push the center of my dashboard back down after it popped out of it's clips. Good luck and don't accept the "that's just how it is" answer.
Everything on the outside lines up nicely. Spacing is fine between the dorr and fender and the door and the bottom frame too
