How do you remove the bottom panel of the dashboard?
Old Nov 23, 2013 | 08:46 PM
LVMonteSS's Avatar
Default How do you remove the bottom panel of the dashboard?
I'm having a hard time trying to take off the bottom panel that has cover's the lower half of the steering column and has the trunk release button. So I can remove my dashboard. I removed the screws and tried pulling it and it will not pop off. I don't want to force anything and break it. I was told it simply "pops off" but it doesn't seem like it does. How do you exactly take it off?
Old Nov 23, 2013 | 09:16 PM
Without looking it over again, i don't recall where all the screws are for it (or how many there are). I will say this, the clips that hold it on hold TIGHT to the car. When you pull on it to pop it out, pull it straight back (don't pull at an angle).
That's the best I can tell you unfortunately.
Old Nov 23, 2013 | 09:47 PM
LVMonteSS's Avatar
Thanks. I had to pry it off and got it off. Now, I have to figure out a way on how I can remove the dash without moving the shifter to 1. Because my ignition is locked and I can't move it.
Old Nov 24, 2013 | 08:47 AM
Not sure you can get the main dash piece out with the shift in park. I never have at least. To make room, if you can't mover the shifter, you may gain some space by taking the shift **** off. Just a thought.
Old Nov 24, 2013 | 05:47 PM
yeah i would take off the shift ****, that would be the easiest way to get it off, its not hard to do, there is a write up in the how to section.
Dec 6, 2014 12:04 PM
monte07
Nov 9, 2012 12:07 PM
77gp
Oct 14, 2012 12:32 AM
spiknek
Aug 17, 2010 09:52 PM
6Kwatt06
Nov 8, 2009 11:33 PM
