help with pillar pod
Old Nov 26, 2009 | 06:00 PM
jimbo7's Avatar
Default help with pillar pod
I'm wanting to install a knock sensor before I start doing any mods to my car and need some examples of everyone's a-pillar pod. All the ones I'm seeing are 3 pods that look like they bolt to the existing pillar cover. As you may know, my monte's pillar cover is one smooth piece that goes from the dash to the back of the door. I'd like to keep this look without any seams or having to bolt on the guage pods. At most i'll just have 2 gauges (kr and maybe intake temp or tranny temp).
let me see what you got!
Old Nov 26, 2009 | 10:50 PM
Dbl_D718's Avatar
I've never seen a two gauge pillar pod, nor have I seen one that doesn't go on top of the factory trim piece. If you find one, let me know lol, because I'm planning on getting a pillar pod over christmas break. Since you're factory supercharged you have a factory boost gauge instead of volts, so in your situation I would just get a volt gauge as a cheap gauge to fill the empty hole.
Old Nov 27, 2009 | 10:11 AM
nemesis's Avatar
2009 Monte Of The Year
that's the only pod you will find, one that go on top of the existing stock one unless you find someone who will do custom made for you.
Old Nov 27, 2009 | 09:12 PM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
thats the only one you'll find unless you go custom and get creative. I always wanted to put gauges underneath the stereo headunit. make a little custom box and fill the little spot up. i have pictures of my 3 gauge setup in my photo album if your curious what it'd look like. i have the ebony interior as you as well. i was skeptical of what it would look like too before i got it, but i decided i had to get it. i did 2 aeroforce gauges and a boost gauge since i did the supercharger kit from zzp. aeroforce gauges are well worth the money.
01 Monte SS
14
Jan 21, 2013 11:57 AM
74NightRider
Aug 28, 2012 05:39 PM
04MONTESSI
Jan 24, 2010 08:06 PM
supercharged05ss
Oct 11, 2009 11:25 PM
Recluse tha Ripper
May 21, 2009 12:49 AM
