help with pillar pod
I'm wanting to install a knock sensor before I start doing any mods to my car and need some examples of everyone's a-pillar pod. All the ones I'm seeing are 3 pods that look like they bolt to the existing pillar cover. As you may know, my monte's pillar cover is one smooth piece that goes from the dash to the back of the door. I'd like to keep this look without any seams or having to bolt on the guage pods. At most i'll just have 2 gauges (kr and maybe intake temp or tranny temp).
let me see what you got! |
I've never seen a two gauge pillar pod, nor have I seen one that doesn't go on top of the factory trim piece. If you find one, let me know lol, because I'm planning on getting a pillar pod over christmas break. Since you're factory supercharged you have a factory boost gauge instead of volts, so in your situation I would just get a volt gauge as a cheap gauge to fill the empty hole.
that's the only pod you will find, one that go on top of the existing stock one unless you find someone who will do custom made for you.
thats the only one you'll find unless you go custom and get creative. I always wanted to put gauges underneath the stereo headunit. make a little custom box and fill the little spot up. i have pictures of my 3 gauge setup in my photo album if your curious what it'd look like. i have the ebony interior as you as well. i was skeptical of what it would look like too before i got it, but i decided i had to get it. i did 2 aeroforce gauges and a boost gauge since i did the supercharger kit from zzp. aeroforce gauges are well worth the money.
