HELP MY LIGHTER DOESN' T WORK
Old Jan 28, 2008 | 10:57 PM
cali2000ss's Avatar
Default HELP MY LIGHTER DOESN' T WORK
My front lighter doesn't want to work I checked the fuses in the drivers side panel and on the passengers side panel and they are both good. Does anybody know of any other fuses or do I have to replace my lighter ? If I have to replace the lighter do I have to remove the center console or can I just pop it out from the front ?
Old Jan 28, 2008 | 11:10 PM
2000LS's Avatar
Default RE: HELP MY LIGHTER DOESN' T WORK
cig fuse is in the fuse box under the hood by the battery and coolant res.
Old Jan 29, 2008 | 10:30 AM
manny's Avatar
ORIGINAL: 2000LS
realy?.i looked at the fuses and it shows that is on the sides of the car...i have lost both my cig. lighters and the fuses are fine ..........
now your saying under the hood by the batt.? what one is it if its there?
Old Jan 29, 2008 | 11:13 AM
bonang's Avatar
look at the cover and it shows what fuses are what.
Old Jan 29, 2008 | 11:25 AM
manny's Avatar
i did that and no sign of cig. lighter under the hood ...only on the side byt the drivers door it shows a fuse for CIG. but the fuse is fine
Old Jan 29, 2008 | 12:53 PM
Hi Manny,
Do you have a electric tester to see `if there is power
to the cig lighter ? Sometimes the socket or lighter itselfgoes bad,
and it needs to be replaced. You can find them at your local parts store.
Also places like AutoZone will test for you.
If it is the socket, make sure your disconnect the battery.
Good Luck, `Space
Old Jan 29, 2008 | 06:12 PM
2000LS's Avatar
well crap, coulda sworn... but yea drivers side panel only...
try checking for power at the fuse with a test light. then at the socket using a ground other than the grounded part of the socket. last check at the socket using the grounded part of the socket.
Old Jan 29, 2008 | 08:14 PM
mickey's Avatar
just make sure what ever you do that you dont test teh fuse for your air bags!!! IT could blow them on you and it is not a cheap repair.
I actually have a small peice of tape on that fuse so i dont cause anythign to hit it by acc.
But you can also check the connections for it.
they are in the center council . to get it off .
1. pull down the leather shift boot carefully.
2. set E brake
3. push clip out of shift handel at the top of the shift lever with small screw driver or a awl (even a nail will work good)
4. pull shift handel straight up.
5. then in the center council at the front (under the dash) pick up the rubber mat.
6. pull the one screw out of it there.
7. open up center cubby.
8. gently pri up on the top part of the councial with a screw driver or anythign you can to pull up on it.
9. once it is up you will see two plugs under there where the heated seat switchswill plug in if you have them (if you dont they have power to them great keyed power switch )
but the cig. lighters can both be reached there and you should beabel to see the wires there eaily enough. if you ya need to do it you cna change them out easily also.
Good luck!!
Old Jan 31, 2008 | 12:05 PM
manny's Avatar
holy crap that sounds like alot of work lol
but i have to get it done..oth are not working and theyare handy to have .....like charging the phone lol........
and space..they are gone i bought 2 new lighters and i get nothing ....so the only thing i can think is the wiring is fried?.......so i will try and do what MICKEY said ..
thanks guys
i love this place.....
Old Jan 31, 2008 | 04:24 PM
mickey's Avatar
the bad part is this is not the source of the wireing i belive it is up under the dash there is a plug there for it behind the stereo or in that area.
If this is the case you can either rewire it and cut the harnes. OR
youcan go to a bone yard to find one and get the whole thing.
OR my fav.
Rewire it but you cut the old harnes that is bad up and get teh plugs on it then rewire it with those int here so it looks and functions like factory
precious1979
Apr 9, 2013 10:11 PM
drock1979
Jan 20, 2012 08:11 AM
03 monte SS
Jul 23, 2008 07:43 PM
Phils01Monte
Feb 25, 2008 10:07 PM
ltrain925
Oct 25, 2007 10:01 PM
