Opinion Needed: Footwell Lighting?
Old Jul 30, 2016 | 06:02 PM
Scott_S's Avatar
Default Footwell Lighting?
What's your opinion on led footwell lighting?
Old Jul 30, 2016 | 11:31 PM
turbo monte's Avatar
I vote do it, led lighting is awesome
Old Jul 31, 2016 | 07:12 PM
Scott_S's Avatar
I'm definitely considering it. I'm thinking of using rgb strips so I don't get tired of any one color.
Old Jul 31, 2016 | 08:09 PM
plumbob's Avatar
Gives off a nice effect for little cost and effort.
I used white LED's in the foot wells, dome light inside mirror (map) lights, and trunk light.
I like the colored lights too, and if ambiance is what you're looking for that would be the way to go, but I don't think they put out quite as much light and not as good for reading by.
Old Jul 31, 2016 | 08:49 PM
Scott_S's Avatar
I'm probably going to keep the dome light white. it's the only light source I have to read with. I might run an rgb extension to the dome light incase I change my mind after I reinstall the headliner. Rgb leds can make white also, so it shouldn't be an issue if I have certain company that don't share my taste in color.
Old Aug 6, 2016 | 03:40 PM
I swapped all my factory lights for LED. My factory footwells have the brightest red LEDs I could find and the upper LEDs (Map and Dome lights) are white/natural color. I had to use the weakest map LED lights to prevent drowning the red. I like the affect. Pretty different.
