Finally, a video of my SA-12's in action
Looks good man!! defiantly notch the top of next box so it can go back further in the trunk
I would think about down firing the subs it will help with everything rattling if you are shooting them down to the strongest part of the car and it will add some DB too (less metal flex) once you eliminate some of the flexing of the deck lid witch is creating some canceling waves costing you DB
disclamer : this is my opinion only and only my opinion baised on my 10+ years of experience in the car audio world and 5 years of comp in semi pro class all over the US
That song gets it doesn't it? My favorite bass song on this setup so far!
You bet man !! Here is my first box it was down firing and was great minis smoking the 2 12 i had in it lol
i will get more picks and see if i can dig up the specks i used on it 5 cubic feet
the box i have for my 2 15" kicker l7 is a sealed back fire and even with the hole truck with 2 layers of dynomat and 2 layers on the deck lid it still moves like crazy i will have to put some viedo and new picks up for sure so u can see what i am talking about
Me ? 12" Dual 4 ohm MTX Thunder Square 8500 Superwoofer Melted the voice coils now have 2 kicker 15" l 7
my hole system was Mtx until 3 weeks ago.. I got it all free!! I was sponsored by them back in 1995 to 2000 ( still had a friend on face book that totally hooked me up )
My fronts MTX Audio TXC6.16-1/2" 2-way Thunder Axe High End Component System in the doors
and 1 extra set MTX Audio TXC.11" (25mm) Thunder Axe High End Teteron Dome Tweeters up by the windshield
I deleted the 6 x 9 's out of the rear deck and factory amp so we could use the locations as ports for the subs and still look stock in the back window
So what car was that box in and what did you compete in as far as sanctioning body?
I have PPI 356CS 6.5" components, running active, 200rms per side.
As did I
![Cool](https://montecarloforum.com/forum/images/smilies/cool.gif)
USAC, and IASCA ( depending wear the show was i wen all over the us and even did a show it Canada )
I had 3 cars I used
1 was a 1986 I Rock Z-28 camaro
2 was a 1988 cavalier z-24 ,
3 was a 1995 camaro Z-28
1 was a sealed box that took the well of the IRock 2 15" orion subs
2 was a 7th order vented enclosure 2 12"s Mtx
3 was a ban pass that had 4 12" subs in it Mtx
