6th Gen ('00-'05): Factory speaker wire colors +/-???
Old Jul 17, 2014 | 01:33 PM
sethrotull99's Avatar
Question Factory speaker wire colors +/-???
I am replacing the factory speakers in my 2005 SS and need to know the + and - colors of the wires at the speaker. Does anyone know this information? I would greatly appreciate the help... Thanks.
Old Jul 17, 2014 | 01:45 PM
SSilver's Avatar
2005 Chevrolet Monte Carlo Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Dark Blue
Old Aug 8, 2014 | 09:21 AM
Thank you
Old Jul 7, 2015 | 08:10 AM
mjv247's Avatar
I have a 2005 LT. What do you all recommend using as the Accessory power Source?
Old Aug 23, 2021 | 12:00 AM
Djscrap38's Avatar
Default I’m trying to connect an aftermarket radio
I’m trying to connect an aftermarket radio in my 05 Monte Carlo how do I bypass the factory amp so I can have sound
prez
May 16, 2020 11:19 AM
spiknek
Aug 29, 2010 08:59 PM
cali2000ss
May 16, 2008 09:34 PM
mtwallet
Jun 11, 2007 10:53 PM
95monte
Dec 27, 2006 05:27 PM
