Factory speaker wire colors +/-???
I am replacing the factory speakers in my 2005 SS and need to know the + and - colors of the wires at the speaker. Does anyone know this information? I would greatly appreciate the help... Thanks.
2005 Chevrolet Monte Carlo Car Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power. Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: White Car Stereo Amp Trigger Wire: White Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Left Rear Speaker Positive Wire (+): Blue Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Blue Right Rear Speaker Negative Wire (-): Dark Blue |
Thank you :)
I have a 2005 LT. What do you all recommend using as the Accessory power Source?
I’m trying to connect an aftermarket radio
I’m trying to connect an aftermarket radio in my 05 Monte Carlo how do I bypass the factory amp so I can have sound
