DRL's
Old Dec 4, 2012 | 04:16 PM
Sweetgtp's Avatar
Exclamation DRL's
How do you shut off the driving headlights? and/or disable the headlights from turning on when you hit the key fob to unlock/lock the doors?
Old Dec 5, 2012 | 11:36 AM
Monteboy03's Avatar
Your factory radio controls the light function when you unlock your car. To adjust its settings, turn the car to Acc, turn your radio off and then press and hold the tune button until a menu appears. This menu allows you to change many features of your vehicle.
The DRL system runs separate from your radio. to disable this is a little more Work. I'll get back to you on this. Gotta double check my info first before I babble
Old Dec 6, 2012 | 04:09 PM
Sweetgtp's Avatar
wow I didn't know that. thanks!
I remember in my gt(p) it had a plug behind/ under the dash on the driverside that connected to a heatsink you simply disconnected this and no more DRL's.
Old Dec 6, 2012 | 04:15 PM
Beside controlling the DRL's....
What else can you change on the Menu?
Old Dec 7, 2012 | 10:17 AM
Monteboy03's Avatar
Well the menu doesn't change the DRL's, it changes settings like when you unlock your car and lock it, if you want the horn to chirp and if the lights should blink. You can set the duration of how long the lights stay on after you shut the car off or when unlocking the car. You can have the doors lock when you shift into gear and unlock either the driver door or both doors when put into park. You can turn on and off your factory alarm. On these radios you can program a new fob. Reset oil life and tire monitor. You can also reset oil life by doing what most GM's do and stomp the gas pedal three times. Lots of little things
Mitchum5543
May 12, 2008 05:20 PM
bonang
May 8, 2008 04:47 PM
White05LT
27
Apr 11, 2008 01:58 PM
cain45
Dec 10, 2006 02:51 AM
04MonteLS
Jun 5, 2005 04:39 AM
