crossover help please
Old May 7, 2010 | 10:35 PM
mak330's Avatar
Default crossover help please
hi i want to get a crossover, but have no expirience with them and saw this, just seeing if its the same thing???
http://cgi.ebay.com/MEMPHIS-AUDIO-EQ...item2a06df1fc6
i know they make an x03 model if that will not work.
i like the look and feel of the factory 6 disc and dont really want to put a shinny HU in there, that makes it look wierd.
will that or a crossover make it sound better and is it worth running something that nice on a stock HU. should i just save up for a nice pioneer???
Old May 7, 2010 | 10:38 PM
mak330's Avatar
also i have non powered crossovers on each of my speakers, if i add something like this should i remove those??? or should i just have my local dealer install. theres a lot of **** on there.
Old May 9, 2010 | 08:00 PM
mak330's Avatar
lol everybodys very tight lipped on this subject. you all usually have a lot to say about audio.
Old May 9, 2010 | 08:26 PM
86_MONTE_CARLO_CL's Avatar
you are able to put a system to a stock head unit my buddy has one in his 09 Cobalt SS Turbo charged.... his amp is hooked up thru crossovers to the rear speakers in the trunk i dont really know how he has it done but you can do it without changing the head unit
Old May 9, 2010 | 10:16 PM
mak330's Avatar
i have a converter/line driver that turns the speaker wires to rca's.
i already have one directional crossovers on my amp. this one will make it so i can isolate the freqencies.
ie mine now only goes 50 and up or 250 and down for the speakers.
with that i can cut it to 75-2000, and phase out anything below 75 and above 2000.
i understand what it does but was wondering if it would be worth it, or if i should just get a aftermarket hu, which i really dont want. i like the clean look.
Old May 10, 2010 | 01:36 AM
just do it the way you were gonna with the stock head unit cause ill tell you what his system hits really really hard with his stock head unit........ well he also paid 1200 bucks for his amp and sub
Old May 10, 2010 | 06:41 PM
mak330's Avatar
ill just try it, it it doesnt help ill just sell/trade it to the local shop. i know they'll trade me for something.
Old May 10, 2010 | 08:03 PM
04MonteLS's Avatar
That piece wouldn't be too bad cause it'll increase the output signal as well which will result in better SQ. If you go that route you could end up with very good SQ for alot less than a nice Pioneer would cost you while retaining the stock look. I say go for it.
Old May 11, 2010 | 04:53 AM
04 dale jr supercharged's Avatar
_I have to agree with u __on this
Old May 11, 2010 | 02:26 PM
04MonteLS's Avatar
The only thing that I don't like about your setup would be that you can't do any time alignment....not sure if you know what that is but it basically allows you to dictate how long the sound from each individual speaker takes to reach your ears. Ideally, the sound from each would reach your ears at the same time but since each one is mounted at a different distance, they don't. In that case, a nice Pioneer would be the way to go cause like on mine, the P880PRS, I can run 3 way active, do time alignment and all that all through my deck, no need for any passive xovers or other external one's like what you posted in the first post.
Up to you though.
