couple of questions
Old May 20, 2010 | 06:39 PM
monte793's Avatar
Question couple of questions
So most people know from my last forum that i need a new box for my 15in sub. I have been looking on ebay for a ported box and it seems that most of the ported boxes are 2.7 to 2.9 cubs, you guys said i should get a 2-2.3 box now does make a difference? also does dynamat make a difference in the door panels?
Old May 20, 2010 | 07:39 PM
04MonteLS's Avatar
Do you have a drill, a phillips screwdriver bit, a jigsaw and some wood glue? If so, I can design you a box, you can go to Home Depot or Lowe's and buy a sheet of 3/4" mdf and they can make all the cuts for you. You just take it home and mock it up, predrill your holes, glue and screw and call it a day! Then all you gotta do is cut the sub opening, predrill the holes for the sub, screw them in and done deal! You just built your first custom box for $35! Your box will need to be 2 cubes sealed or 2.3 cubes ported
Sound deadening makes a big difference, a very worthwhile cost when doing a nice sound system.
Old May 20, 2010 | 07:51 PM
monte793's Avatar
ok well does it have to be ported because it seems like there is a lot more technical work to it beside just cut and put together
Old May 20, 2010 | 08:16 PM
04MonteLS's Avatar
Unless you're designing the box you won't have any technical work besides screw and glue.
But to answer your question, no, it doesn't have to be ported. That's totally up to you. Just know that a ported box will hit deeper and get louder, while a sealed will give you cleaner, more accurate bass, it'll be more punchy than boomy. So if you listen to mostly rock music, you'd probably appreciate sealed more. But if you listen to a fair share of rap music, you might want to go ported. It's up to you though. So let me know if you want me to hook you up with a design and what type of box you want and I'll make it happen.
Old Jun 15, 2010 | 04:52 AM
gdixonjr's Avatar
Can i get a design? I have 2 15" rockford fosgate p1's and would like to have a ported box for my 04 monte. thx in advanced.
Bladesinger
Sep 26, 2008 04:19 PM
ss.kyle91
Aug 12, 2008 05:56 PM
Brinksta
Aug 3, 2008 02:34 PM
98monte
Feb 28, 2008 01:18 PM
Epic
Oct 7, 2007 11:57 AM
