Cooling My Amp
Old Apr 22, 2010 | 12:00 PM
Dbl_D718's Avatar
An amp isn't really going to draw more power once it's hot, so don't worry about that. Your battery and alternator will be fine, at least in this sense.
Both of my amps are cooled with heatsinks and they've never over heated on me (the heatsinks are huge though). Computer case fans won't hurt anything, but I can't imagine them helping much either. If you really want to go fan-cooled, you'll need a more substantial fan, like this one:
http://www.darvex.com/SGJ76/Stinger+...sflow+Fan.html
Old Apr 22, 2010 | 12:03 PM
Originally Posted by Overdose666
I know sir lol
okay LOL no need to get hostile.
since youre good with computers, you could run the wires from the fan off the power inputs on the amp with no need for an inline fuse. (LOL but you already knew that) (sir)
jk by the way
Overdose666's Avatar
Ah but that cost money my kind sir lol, i just happen to have about 6 8cm case fans lying around, at this point any air flow will be helpful lol
Old Apr 22, 2010 | 12:07 PM
Dbl_D718's Avatar
Well I also assumed you wouldn't want to be openning up the amp, so that was more aimed at external air movement. I can't say much about internal fans, but I don't even know if an 8cm fan would fit inside in any useful way.
You could maybe line the external part of the heatsink(s) with fans since you have them. Just seems like a lot of effort to keep a junk amp from overheating lol.
and yes, hotter electronics draw more amperage.
Old Apr 22, 2010 | 12:09 PM
Hey man if u look at the pics of my car you can see i'll do as much work as possible to spend as little money as possible
Old Apr 22, 2010 | 12:20 PM
Step 1: Open Trunk
Step 2: Buy batteries
Step 3:
Old Apr 22, 2010 | 12:51 PM
Budsjlm's Avatar
it may be the same amps i had what i did was pull the 4 pulled the corners on the top pulled top cover off and drilled some holes in it then cut a hole where it says dual and mounted a comp fan on it
Old Apr 22, 2010 | 01:01 PM
Pure2sin's Avatar
That is what happens to cheaper amps. I had a cheap Phoenix Gold amp (Which used to be a REALLY good brand) now they crap. It used to overheat not right away but after 30 min. Go by a laptop cooler and hard wire it into your car and set the amp on top of it lol. I laugh but that actually might be a good idea. I hear pouring a bucket of water over amps helps to cool them off too lol.
PS- Don't call me Sir that my dad.
Old Apr 22, 2010 | 09:16 PM
wow, LOL what happened to that poor thing? i mean the front bumper?? OUCH!!
