6th Gen ('00-'05): Change bulb
Old Sep 2, 2014 | 07:08 AM
afterburner34's Avatar
Default Change bulb
The climate conrol light on my center dash went out (Passenger heat and cool). How would I change the light? It doesnt appear I can go from under neath so would I need to take all the inteior trim covers off to get to it? And does anone know what bulb to use?
Old Sep 2, 2014 | 07:28 AM
If your speaking of about the lights for the slider controls, the unit has to be removed to repair them. The bulbs are soldered in place and from what I understood this is meant to be a whole unit replacement, a non-repairable item.
I ended up getting a different unit off of eBay for like $35 and swapped it out with my malfunctioning unit. I wrote the seller and told them they needed to make sure the light bulbs were working as thats why I'm buying it. It's just a plug-n-play situation then instead of finding the minature bulbs and soldering them into place.
A member posted a video on YouTube on how to repmove and replace the dash bezel, pretty easy cheesy, a few screws and a few electrical snap connectors and it's out.
Old Sep 2, 2014 | 07:31 AM
gprtech's Avatar
IF you're talking about the illumination of the panel, those are just small leaded 12V bulbs that are soldered in place.
If you're talking about the lights behind the buttons, those are LEDs. It's unlikely that one would burn out. It could be a broken solder joint.
Old Sep 2, 2014 | 07:47 AM
Yes it is the slider controls. And I dont think its the whole unit as it was out before and when I did a new sub and amp the company replaced the bulb for me so it is by parts
Old Sep 2, 2014 | 08:12 AM
I know a member a while ago put led strips in his and it didn't look bad because it lit up everything. Here is the link. https://montecarloforum.com/forum/in...version-47288/
Old Sep 2, 2014 | 08:19 AM
The whole unit generally doesn't go out, the solders on the lights will break instead. Sometimes hitting the HVAC unit with some good force will realign those solders until they get worse again.
Or you can watch my video above to pull out the HVAC and get yourself a new one.
dcnaser
Mar 25, 2012 07:40 PM
jasonsmith
Feb 5, 2012 10:46 PM
drmrgal
Apr 8, 2011 05:11 AM
Budsjlm
Oct 19, 2009 09:53 AM
Monte_04
Oct 28, 2007 07:36 AM
