Cd stuck
Old Apr 28, 2011 | 11:45 PM
06SSMonteCarlo's Avatar
Default Cd stuck
I got a 2006 Monte Carlo SS....I got 5 cd's in my cd changer at the moment, they are all jammed, I try to eject them but the car can't even read them, or if I try load a new disc it doesn't let me....anybody know the easy/cheap way out?
Old Apr 29, 2011 | 01:50 PM
mikowolf's Avatar
i posted the exact same question a few days ago. although i only have 1 cd stuck. i haven't got an answer back yet but if i do i'll let you know. hope you do the same for me. do you know the name of the stereo? i'm going to google it to see if i can find an answer but i need the name. thx
Old Apr 29, 2011 | 02:11 PM
is there a pinhole button type thing like on the old computers that maybe will push the disc out?
Old Apr 29, 2011 | 09:43 PM
mikowolf's Avatar
haven't seen one in the front and haven't taken the dash apart to check out the back.
Old Apr 30, 2011 | 12:00 AM
Geddy's Avatar
I own a 2006 Monte as well and could not load a CD or unload the existing one I had in the player. I tried everything and ended up having the factory radio/CD replaced with a refurbished one from the dealer. So far the refurbished is holding up.
Old Apr 30, 2011 | 01:52 PM
Jester_20's Avatar
i know with my aftermarket receivers, i couldn't use a cd that i'd put a label on because that extra 1/2 mm made it too thick to eject, i always had to take another cd and push down/up on the cd that was in the deck, but the problem you are having may not be because of the cd. good luck
Old Apr 30, 2011 | 02:08 PM
03SSLE's Avatar
Old Apr 30, 2011 | 03:53 PM
mikowolf's Avatar
thx i will try these and post back. i did find a hole but i think its an aux port.
Old Apr 30, 2011 | 05:10 PM
walkingonabullet's Avatar
Old Apr 30, 2011 | 05:15 PM
Jester_20's Avatar
hahaha!!
