Cd stuck
I got a 2006 Monte Carlo SS....I got 5 cd's in my cd changer at the moment, they are all jammed, I try to eject them but the car can't even read them, or if I try load a new disc it doesn't let me....anybody know the easy/cheap way out?
i posted the exact same question a few days ago. although i only have 1 cd stuck. i haven't got an answer back yet but if i do i'll let you know. hope you do the same for me. do you know the name of the stereo? i'm going to google it to see if i can find an answer but i need the name. thx
is there a pinhole button type thing like on the old computers that maybe will push the disc out?
haven't seen one in the front and haven't taken the dash apart to check out the back.
I own a 2006 Monte as well and could not load a CD or unload the existing one I had in the player. I tried everything and ended up having the factory radio/CD replaced with a refurbished one from the dealer. So far the refurbished is holding up.
i know with my aftermarket receivers, i couldn't use a cd that i'd put a label on because that extra 1/2 mm made it too thick to eject, i always had to take another cd and push down/up on the cd that was in the deck, but the problem you are having may not be because of the cd. good luck:o
Maybe one of these solutions will work?
Car CD player eject problems | All cars stuff from A-Z you ever wanted |
thx i will try these and post back. i did find a hole but i think its an aux port.
hahaha!!
