Bench seat to Buckets plus console
Old May 11, 2012 | 09:30 PM
chevy402mc's Avatar
Default Bench seat to Buckets plus console
Got a 3rd Generation Monte Carlo (1978) "305" automatic with bench seat. Would like to switch to buckets and install a console. My problem is figuring out what would be a good donor for the items. I want to keep the automatic if this makes a difference in the console. Any help or ideas out there.
Old May 18, 2012 | 12:54 PM
Zeke's Avatar
- Pontiac GPs. Have GP buckets in my 82 El Camino. Forget the whole console, get your mitts on something like a B&M MegaShifter, like me. =)
Old May 19, 2012 | 03:17 AM
mid 70's Grand Prix, Regal or cutlass. Or you could go with a modern interior from anything with a wider body style like a Bonneville or a Cadillac. Maybe even a Chrysler sebring or newer charger. You can make anything work with a little imagination and some creativity.
Old May 20, 2012 | 09:14 AM
TheMonteMan's Avatar
i have the correct console for that car. you could buy it off of me. was never a huge fan of them, but they are worth tons of money. the mid 70s stuff is probably going to be way too long. i currently run buckets from a 80s charger, and a megashifter. i doubt any of the other factory consoles will fit without major modification, with the exception being the 78-88 gbody stuff(obviously). buckets are pretty much about measuring. your best bet for this conversion is to find a 4th gen monte ls with buckets and a console, and take everything with you. pm me if you are interested in the console. its a burgundy color and has everything except the ash tray door. i have no idea where that has made its way to. i was using it as a template to make a spot for a gauge cluster. you can also run a aftermarket shifter in it. i ran it with a promatic 2 instead of the factory shifter with no problems.
Sebastian Thonet
Sep 3, 2014 11:17 AM
VincentG
Dec 9, 2013 04:09 PM
1984-monte-carlo-ss
Jun 15, 2011 07:00 PM
original87SS
Feb 27, 2011 12:36 AM
scc24540
Aug 16, 2007 12:18 PM
