audio help
Old Jan 9, 2009 | 04:56 PM
NTIMD8T's Avatar
Default audio help
thinking of replacing h/u as lights in radio burnt out.. sorry probably know the answer is here but I am using my cell as my pc video card crashed... do I have to get the expensive harness to change to aftermarket? not worried about chimes and such.. just want a night time display back... and do i need to do anything special with the rear amp..
03 monte ls with factory single disc (non) bose
I know will loose sat radio as I have sirius that plugsto factory deck but have an extra add on unit and a pioneer deh p9800t that was in my neon
thanks in asdvance..
ntimd8t
Old Jan 12, 2009 | 03:28 PM
aussiek2000's Avatar
Default RE: audio help
I just hooked into the old wires. You will have to run an acc. 12v because the stock radio doesn't use one. I just used an acc. wire from the heater controls. You will also loose door chimes.
SoChicago
Jun 17, 2009 08:21 PM
patch317
Jun 1, 2009 07:53 AM
jasonmcr
Jan 26, 2008 07:59 PM
jasonm56
May 1, 2007 08:56 AM
