Apexi Airflow Converter
Old Aug 16, 2009 | 03:59 PM
musclecarfreak1235's Avatar
Default Apexi Airflow Converter
I have a apexi airflow converter and was wondering if anyone knows how to wire it up to my pcm
Old Aug 16, 2009 | 04:18 PM
Hi `MuscleCarFreak & Welcome to our MCF Family.
What year/model is your Monte Carlo.
Did you have the manuel ?
Check the below PDF & see if that helps you
If it does not, check back on your thread to see `if any
of our Expert Tech Member's can assist.
What other Mod's do U have ?
Wish you Good Luck...Let us know how it goes `ok.
[PDF]
SUPER AIRFLOW CONVERTER
File Format: PDF/Adobe Acrobat - View as HTML
and precautions for the Super Airflow Converter, refer to the. Instruction Manual. When installing the Super Airflow Converter, both this document ...
www.apexi-usa.com/content/pdf6119.pdf - Similar
Apexi SAFC Air Flow Converter from AlamoMotorsports
Apexi SAFC Air Flow Converter from AlamoMotorsports.
www.alamomotorsports.com/apexi/safc.html - Cached - Similar
Old Aug 17, 2009 | 10:27 AM
I have a 2005 Monte Carlo SS w/ Supercharger
I really need like a wiring diagram for the pcm so i know what the wires from the pcm go to(power supply, engine knock, throttle signal, ground, etc...), the manual did help, cause my cousin had it and didn't want it, and i didn't have the manual, but now i just don't know what the pcm wires go to
Old Aug 17, 2009 | 10:34 AM
If one of our Expert Member's does not post or
have a manuel. I suggest contacting the
company & see if you can order one from them, or
ask your cousin if he can find the one that came with the
unit. Good Luck from `Space
FayLynn
May 12, 2015 04:08 PM
Faster
Oct 9, 2013 11:31 AM
BeachBumMike
Aug 16, 2007 04:53 PM
fake SS guy
Nov 28, 2006 09:23 PM
