amp question
Old May 27, 2008 | 11:20 AM
schmicr's Avatar
Default amp question
i have a quick question to make sure i am right before i buy this amp
[ul][*]RMS Power Ratings:[ul][*]70 watts x 2 chan. @ 4 ohms[*]100 watts x 2 chan. @ 2 ohms <-------- does this give 100 watts to each channel? its a 2 channel amp[*]200 watts x 1 chan. @ 4 ohms[/ul][/ul]
http://www.sonicelectronix.com/item_...+ZX200.2.html#
Old May 27, 2008 | 12:26 PM
schmicr's Avatar
Default RE: amp question
nevermind i figured it out
Old May 27, 2008 | 12:30 PM
schmicr's Avatar
just purchased two amps today, hopefully i will be able to start hooking them up this weekend.
Product Description:
Kicker ZX200.2 [ul][*]2-Channel ZX-Series Power Amplifier[*]Low Impedance Operation[*]SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)[*]MOSFET Power Supply[*]KickBass: 0-12 dB @ 40 Hz[*]Built-In Electronic Crossover: 12 dB High or Low-Pass operation (80 Hz)[*]High & Low level inputs[*]Custom tooled gold plated connectors[*]SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time[*]Cast Aluminum EndKaps[*]RMS Power Ratings:[ul][*]70 watts x 2 chan. @ 4 ohms[*]100 watts x 2 chan. @ 2 ohms[*]200 watts x 1 chan. @ 4 ohms[/ul][*]Input gain control: Low Level (125mV - 5V), High Level (250mV - 10V)[*]Authorized Internet Dealer[*]2-year Manufacturer's warranty[/ul]
Kicker ZX750.1 [ul][*] mono subwoofer amplifier[*] 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)[*] variable low-pass filter (50-200 Hz at 24 dB per octave)[*] variable bass boost (0-18 dB at 40 Hz)[*] subsonic filter (12 dB at 25 Hz)[*] wired remote bass level control[*] Class D design[*] CEA-2006 compliant[*] speaker-level inputs[*] preamp outputs[*] fuse rating: 40A x 2[*] requires 4-gauge power and ground leads — 80 amp fuse recommended, wiring and hardware not included with amplifier[*] 14-11/16"W x 2-5/16"H x 9-5/8"D[*]Authorized Internet Dealer[*]2-year Manufacturer's warranty[/ul]
One Dark SS
Nov 11, 2009 11:34 AM
Aug 8, 2009 05:05 AM
Latch
Mar 17, 2009 09:33 PM
victoryred05
Jan 10, 2007 02:45 PM
