Does your system have a second battery
Old May 15, 2008 | 05:16 PM
zipsayain's Avatar
Default Does your system have a second battery
Does your system have a second battery. And if so, how do you have it setup (pics) ?
Old May 15, 2008 | 05:25 PM
sickofsoyo's Avatar
Default RE: Does your system have a second battery
I dony have one currently, but I plan on getting one with my second amp... it will have 0 guage with 300 AMP ANL fuse running to the trunk, and it will be wired there. If you do a second battery, I recommend a larger alternator to supply power to both.
Old May 15, 2008 | 06:32 PM
04MonteLS's Avatar
ORIGINAL: zipsayain
No, I don't plan on playing it for long periods of time without the car running, and it's not a bestly system either so I don't have a need for one at the moment.
Old May 15, 2008 | 06:44 PM
mickey's Avatar
NOPE!! and i due play mine all the time with out running the car BUT i have replace the Alt. with a larger version (largest i could find for the monte carlo at auto zone)
And also have a yellow top optium battery. and have never had a isse with it other then when the first Bat. i had lost a cell and that was replaced under thier warrenty and was found it was actually due to the fualt of the Bat. not the system
Old May 15, 2008 | 07:12 PM
04MonteLS's Avatar
that's the nice thing about having a deep cycle battery in your car, it's meant to lose power slowly over a long period of time.
Old May 15, 2008 | 08:50 PM
zipsayain's Avatar
What about using a Capacitor?
Old May 15, 2008 | 09:20 PM
mickey's Avatar
i had one in the last set up but it was not really somethign i had to have . But they will help some but are not a fix for the disco lights tha tyou get from a system with base.
get a better Bat. and Alt. for the car and it will handel the power drains better.
Cap.'s tend to be more of a bandaid then anythign and cause you to have to replace those anyway.
Old May 15, 2008 | 10:00 PM
04MonteLS's Avatar
ORIGINAL: mickey
True story.
The only thing I'd add is that you should also do the Big 3 ground upgrade too.
Old May 16, 2008 | 05:57 AM
bonang's Avatar
Did you ever see the starter in a 07, Try getting to it from the to lol
Bigger battery (yellow top/Deep cycle), Big three upgrade, good grounds from the amp(s) and nice quality power/ground cable will make the system nice.
Old May 25, 2008 | 07:24 AM
RocknSS04's Avatar
YES! I WOULDN'T BE WITHOUT IT! Having snow plow trucks in the past, and having dead batteries, it was a MUST to have 2 batteries! I ran a battery isolator on the battery running the plow. I have a battery isolator for this car, but it wasn't installed. I have a true dual battery system. The front battery is an Optima red top, while the battery in the trunk is an Optima yellow top. I have a co-worker who had 3 batteries to run his sound system!
There are more pics on my photobucket siten and my cardomain site. The cardomain site isn't current, as my new system just got put in last week, and the cardomain site hasn't been updated yet, but the battery stuff hasn't changed any. Here is a link to my photobucket account:
http://s243.photobucket.com/albums/f...s04/?start=all
