Amp hook up
yeah....if you want your lights to dim! The power wire on the factory amp is what, 20ga? Not exactly the preferred diameter for running a high powered amplifier.
Well, yes and no. The reason the main power wire is fused is to prevent your car from catching fire in the even of a catastrophic failure, not to protect your amp. The fuses on the amp are there to protect it. You should fuse the power line based on the amount of current the wire can carry.
But using a smaller fuse than the rated amperage of the wire won't hurt anything, I just wanted to clarify the purpose of fusing the main power line.
Wow, for the last 10 years, Ive been installing amps off of that logic. Oh well, thanks for clearing it up for me.
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
I got a question here that might be helpful since there is wire diameter in question. I used to have a 1200 W rms amp ( or somthing close) and I was ALWAYS unhooking it and putting different subs and wires to it and such. There was a time I was using 8G wire and it sounded better than it did with 4G. This was the power wire mind you(going to the battery) What is the deal with power wires having an effect on sound quality??
Also, I had a friend that swore by all that using 4G wire for speaker wire was good to do, is this by any means true??
Thanks again...
Normally for a 1200w amp you will want to run a 6g wire. I have a 1200.1KX Kicker amp powering 2 JL Audio W3's I have used 4g wire before with it and didnt take the wiring out when I got a new car but I couldn't tell any difference in the sound quality from the different sizes. 4g wire is good to use but you need to remember that you do need some resistance so you need to always figure the power to wire size ratio because you deffinately don't want to go to big. I hope this helps some.
It's a common misconception, but one that won't necessarily result in a failure like you described if done with some thought. Usually if anything bad happens its that you have to keep replacing the fuse cause you amp is pulling more current than the fuse will allow. So it'll work so long as your amp isn't pulling more current than what the fuse will allow, I was more trying to clear up why that line is fused.
I have one more question. I just wanted a little more out of my receiver so I went with a 400 watt 4 channel amp, it does have high level inputs would it still be best to get the line out converter so I could use RCA's? Would there be a noticeable difference in the sound quality? Oh, that's two questions, sorry.
thanks...
thanks...
4ga for all speaker wires is akin to using a sledgehammer to kill a fly. So not necessary, it'll get the job done but kind of a bit much.
thanks...
thanks...
boston989
17
10-05-2014 03:17 PM
Intimadator4
05-27-2006 06:33 PM
