Aftermarket amp
Old Aug 2, 2012 | 09:02 PM
Justin Myers's Avatar
Default Aftermarket amp
I have a 2000 LS I plan on keeping my factory radio using SNI-35, but my question is can I tie my aftermarket amp remote wire in with my factory amp, if so does anyone know what wire to tie into or have a diagram?
Old Aug 3, 2012 | 12:32 AM
You can always use the AUX fuse as a remote wire.
You're not going to power the stock speakers, right?
Old Aug 3, 2012 | 09:47 AM
I would like to have at least the components powered, I'm not to worried about the 6x9's in the back
Old Aug 3, 2012 | 11:48 AM
I would be very leery of powering any of the stock stuff. They're only little paper woofers and people often have trouble with them blowing off stock power.
You may want to upgrade the speakers also
Old Sep 23, 2012 | 09:57 PM
Milhouse's Avatar
You could but it's not recommended as the factory wiring was just meant to support the factory components only, added another load to that could cause issues. Best option would be to run your remote lead from your fuse box.
Old Sep 23, 2012 | 11:50 PM
some line-outs have a remote wire on them, so you may want to look into a different one, or else you can run a small power wire back from the AUX fuse which comes on with the car.
Old Sep 25, 2012 | 11:20 PM
Hiroska's Avatar
Just run a wire to the fuse or even you ignition as a remote.
Old Sep 26, 2012 | 12:09 AM
monte06ltz's Avatar
run the wire wright to the fuse box and hook it to a switch thats what i did then if you dont want it on you can always turn it off i turn mine off when i get close to home so nobody knows i have it
MIKE07083
Aug 15, 2010 01:48 PM
MIKE07083
Aug 15, 2010 02:26 AM
rgant_19
Feb 3, 2009 12:16 AM
jpe
Sep 2, 2008 11:30 PM
duner
Jul 8, 2008 11:03 PM
