Ac fixed/ now broken again......
Old Jul 20, 2014 | 10:18 AM
03monte ss - Red Baron's Avatar
Default Ac fixed/ now broken again......
Got my ac fixed like 2/3 weeks ago and recently it started blowing warm out of the drivers and cold on only the passenger vents - then 2 days ago it started to blow only warm air on each side . Does anyone know quick fixes for this because i already had it fixed at a shop and they vacuum tested it and their system said it had no leaks and it was like 55/60 coming out but now its blowing warm and i don't want that - any places to start?
Old Jul 22, 2014 | 02:07 PM
Bump please? - its like 95 today....
Old Jul 22, 2014 | 02:23 PM
Only thing I can think is that it actually did leak out.
Instead of a pressure test, they should inject a dye with a refill and then check it with black lights.
Old Jul 23, 2014 | 09:04 AM
03SSLE's Avatar
Other possibilities could be the Door Actuator Mode Valve or the Temp Door Actuator
Old Jul 23, 2014 | 08:58 PM
A05C's Avatar
If its cold at all that means that there's refrigerant in the system.
a split temperature between one side or the other is a temperature blend door or blend door actuator/motor
Old Jul 23, 2014 | 10:31 PM
Sounds like blend door actuator or possibly a combination of both issues.
Jessee Nienhuser
Oct 21, 2014 12:11 PM
Wss92271
Oct 8, 2014 05:58 AM
WannaMCSS
Dec 14, 2011 09:27 AM
Dale3goodwrench
Jun 1, 2010 01:17 PM
RocknSS04
Jan 13, 2008 06:17 PM
