Ac fixed/ now broken again......
Got my ac fixed like 2/3 weeks ago and recently it started blowing warm out of the drivers and cold on only the passenger vents - then 2 days ago it started to blow only warm air on each side . Does anyone know quick fixes for this because i already had it fixed at a shop and they vacuum tested it and their system said it had no leaks and it was like 55/60 coming out but now its blowing warm and i don't want that - any places to start?
Bump please? - its like 95 today....
Only thing I can think is that it actually did leak out.
Instead of a pressure test, they should inject a dye with a refill and then check it with black lights. |
Other possibilities could be the Door Actuator Mode Valve or the Temp Door Actuator
If its cold at all that means that there's refrigerant in the system.
a split temperature between one side or the other is a temperature blend door or blend door actuator/motor |
Sounds like blend door actuator or possibly a combination of both issues.
