85 monte column swap and now no Dash cluster lights or dome light?
Old Jun 4, 2014 | 06:53 PM
BigRedGroceryGetter's Avatar
Default 85 monte column swap and now no Dash cluster lights or dome light?
I recently swapped out and put in a new steering column in my 85 MC...Lets make a long story short. I turned the key and something snapped in the column.. I took it a mechanic and he tore it apart stating that the best thing to do was to go to a junk yard and just buy another gbody column...now the new column is in but when i turn the headlight switch wheel there are no Dash cluster lights or dome lights? I have checked the fuses but I am not sure which fuse would operate the dash cluster or dome light as i do not have the manual.. could there be a harness underneath the dash that i could of bumped or something to that effect as to why I am not getting any lights inside? I also swapped out the headlight switch ($30 waste) and it did not work...any help or advice would be appreciated....thanks jeff
rg9johns
Jan 2, 2022 05:51 PM
matthew41
Jan 25, 2015 11:22 AM
rg9johns
Aug 22, 2014 10:46 PM
PapaBuggz
Apr 22, 2012 12:28 PM
bbrewbaker
Mar 2, 2009 07:59 AM
