2007 Monte Carlo LS DVD Vid Install
Just got inside from running my amp power wire....which was eaiser then I thought. and finsihed the wire harness and tested and it works aok. Head unit powers up and I even played a movie lol. I just have to wait for my dash kit thats should be here MOnday.
ORIGINAL: bonang
You have a alpine unit dont you?
This kenwood has a park switch wire that just needs to be grounded so I grounded it with the deck ground.
Well after some thought and looking in the engine bay, I found my hole in the firewall. I pulled the carpet back on the passenger side and to find the main wire harness coming in the car. I just used that. In order to get to it I had to move the Coolent overflow for now. Two nuts and its moves. Then there was TONS! of room.....for a childs hand lol
![](http://i17.photobucket.com/albums/b56/pibkac/monte_carlo/PC050014.jpg)
This is the gromet I used to go into the passenger bay.
![](http://i17.photobucket.com/albums/b56/pibkac/monte_carlo/PC050012.jpg)
I then ran the wire along with the wire harness and tie wraped it.
![](http://i17.photobucket.com/albums/b56/pibkac/monte_carlo/PC050013.jpg)
Then ran it on the brace and tied the fuse holder to this and you can not even see it. I love it.
And here is the harness all done and tested:
![](http://i17.photobucket.com/albums/b56/pibkac/monte_carlo/PC050010.jpg)
The two white connection connect to the GM0S Lan 01 Box that is currently mounted in my dash.
