2007 Monte Carlo LS DVD Vid Install
Old Jan 10, 2008 | 06:47 PM
bonang's Avatar
Default 2007 Monte Carlo LS DVD Vid Install
Head Unit: DDX6019
Adapter: GM0S-LAN-01
Old Jan 10, 2008 | 08:51 PM
mickey's Avatar
Default RE: 2007 Monte Carlo LS DVD Vid Install
lookin good . i do the same as you did here with the soldiering and shrink wrap.
makes life easier and i know it wont come apart easily
Old Jan 10, 2008 | 09:02 PM
bonang's Avatar
and not a bulky with crimps.
Old Jan 11, 2008 | 04:55 PM
04 Intimidator's Avatar
Very nice. Did you need to get a safety bypass so you can watch it while you drive? Mine cost about 15 bucks.
Old Jan 11, 2008 | 05:59 PM
bonang's Avatar
You have a alpine unit dont you?
This kenwood has a park switch wire that just needs to be grounded so I grounded it with the deck ground.
Old Jan 11, 2008 | 06:33 PM
mickey's Avatar
the pioneer version needs to be switched ground to get it to work.
meaning that you have to flip the switch to ground it then wait a sec. and flip it back to get it to work
Old Jan 11, 2008 | 06:50 PM
bonang's Avatar
Monday or Tuesday I will have the dash kit in stock so I hope to get in sometime early next week.
Old Jan 12, 2008 | 01:33 PM
bonang's Avatar
Just got inside from running my amp power wire....which was eaiser then I thought. and finsihed the wire harness and tested and it works aok. Head unit powers up and I even played a movie lol. I just have to wait for my dash kit thats should be here MOnday.
Old Jan 12, 2008 | 02:53 PM
ORIGINAL: bonang
Yeah, it is an alpine. I'm not sure how the park registered so I just bought the bypass.
Old Jan 12, 2008 | 04:47 PM
bonang's Avatar
Well after some thought and looking in the engine bay, I found my hole in the firewall. I pulled the carpet back on the passenger side and to find the main wire harness coming in the car. I just used that. In order to get to it I had to move the Coolent overflow for now. Two nuts and its moves. Then there was TONS! of room.....for a childs hand lol
This is the gromet I used to go into the passenger bay.
I then ran the wire along with the wire harness and tie wraped it.
Then ran it on the brace and tied the fuse holder to this and you can not even see it. I love it.
And here is the harness all done and tested:
The two white connection connect to the GM0S Lan 01 Box that is currently mounted in my dash.
