2006 Monte ss Stock amp
Old May 4, 2008 | 08:56 PM
ffej06montess's Avatar
Default 2006 Monte ss Stock amp
Hi all,
Does anyone know if the stock 200 watt amp just runs the 2 rear 6x9's or does it also run the front door speakers? I'm looking to keep everything the same maybe just buy new speakers and need to know if i should buy all 4 or just the 2 rear.
Old May 5, 2008 | 06:59 AM
rysZ34's Avatar
Default RE: 2006 Monte ss Stock amp
It runs the whole system.
Old May 7, 2008 | 07:48 PM
zwc0442's Avatar
You better check and see what the your factory speakers ohm resistance is. I have and 02 and the factory speakers are all 2 ohm and the majority of the aftermarket speakers are 4 ohm. So if you run a set of 4 ohm speakers if will basically cut the power that the amp puts out in half. Which is not nearly enough power to make use of the new speakers.
Hiroska
May 19, 2014 04:23 PM
dezzyboi16
Jan 21, 2013 12:16 PM
paintballerr78
Dec 10, 2009 09:40 PM
One Dark SS
Nov 11, 2009 11:34 AM
mcarloss04
Sep 21, 2005 03:10 AM
