2003 Monte Carlo Crackling/Distortion with GM0S-04
Old Jul 28, 2011 | 09:12 PM
Lthorn14's Avatar
Default 2003 Monte Carlo Crackling/Distortion with GM0S-04
I have a 2003 monte carlo, it is not the ss. I have a factory amp with bose but no onstar. After installing an aftermarket subwoofer, amp, and headunit with the GM0S-04. My sub sounds amazing but my front speakers are crackly and distorted. Also my back speakers are having no issues. I have adjusted the potentiometer audio level every way possible but this doesn't solve my issue. My headunit is a pioneer DEH-P3800MP with a preout voltage of 2.2.
Could this be caused by a setting on my headunit?
Could this be because the GM0S-04's RCA cables had been cut off and is connected with wires instead?
Does anyone know a solution to this problem?
If you need any additional information just ask. Thanks in advance for any help.
Old Jul 28, 2011 | 10:17 PM
Milhouse's Avatar
Originally Posted by Lthorn14
I have a 2003 monte carlo, it is not the ss. I have a factory amp with bose but no onstar. After installing an aftermarket subwoofer, amp, and headunit with the GM0S-04. My sub sounds amazing but my front speakers are crackly and distorted. I have adjusted the potentiometer audio level every way possible but this doesn't solve my issue. My headunit is a pioneer DEH-P3800MP with a preout voltage of 2.2.
There is no Bose option on the 00-05 Monte's, just a FYI. You do have the premium system though......
When you removed the factory head unit there were two plugs back there, are both of those plugs plugged into the gmos-04? If so, I think the problem is the amp on the deck and the factory amp both trying to power the speakers. I think if you disconnected the smaller black plug I think the issue would go away. You gotta take the factory amp out of the loop, I've done so by simply not plugging the black plug in to anything behind the deck.
I hope that helps
Old Jul 29, 2011 | 08:50 AM
Lthorn14's Avatar
Thank you for your quick response. I just tried that and the issue is the same with or without the plug.
Edit* After doing some research I think the only solution is to remove/bypass my amp. I don't know the wiring diagram and don't want to cut factory wires. Any ideas as to how to bypass without cutting factory wires?
Old Jul 29, 2011 | 04:31 PM
Milhouse's Avatar
Just out of curiosity, did you plug the factory deck back in to see if the crackling remains? If it goes away then the problem is your module. I'd give that a shot before anything else.
Old Jul 29, 2011 | 05:20 PM
one problem i have had is crappy quality of some of the music i downloaded, where are you getting your music from?
Old Jul 29, 2011 | 07:19 PM
Milhouse's Avatar
Yeah, that too can be a problem the better your system gets. But im not too sure thats the issue here.
Old Aug 1, 2011 | 07:04 PM
Lthorn14's Avatar
The speakers sound fine with the factory hu. The sound is bad with actual cds (not burned) and with the radio. I ordered the AOEM-GM24 because im tired of messing with this aftermarket hu. Anyone had any luck with this module? It helps add rca cables for an amp with your factory hu
Old Aug 2, 2011 | 08:30 PM
Milhouse's Avatar
Oh well, you gave up so no sense in me continuing trying to help.
Old Aug 4, 2011 | 07:22 PM
Lthorn14's Avatar
I didnt give up, I never give up! lol. I figured the gmos-04 was faulty and I got a full refund. After reading I saw only negative reviews about that module, so I decided to try the aoem-gm24. Ill let you know how it goes.
Old Aug 4, 2011 | 09:43 PM
Milhouse's Avatar
So you're still gonna run the aftermarket head unit?
