2003 Monte Carlo Crackling/Distortion with GM0S-04
I have a 2003 monte carlo, it is not the ss. I have a factory amp with bose but no onstar. After installing an aftermarket subwoofer, amp, and headunit with the GM0S-04. My sub sounds amazing but my front speakers are crackly and distorted. Also my back speakers are having no issues. I have adjusted the potentiometer audio level every way possible but this doesn't solve my issue. My headunit is a pioneer DEH-P3800MP with a preout voltage of 2.2.
Could this be caused by a setting on my headunit?
Could this be because the GM0S-04's RCA cables had been cut off and is connected with wires instead?
Does anyone know a solution to this problem?
If you need any additional information just ask. Thanks in advance for any help.
I have a 2003 monte carlo, it is not the ss. I have a factory amp with bose but no onstar. After installing an aftermarket subwoofer, amp, and headunit with the GM0S-04. My sub sounds amazing but my front speakers are crackly and distorted. I have adjusted the potentiometer audio level every way possible but this doesn't solve my issue. My headunit is a pioneer DEH-P3800MP with a preout voltage of 2.2.
When you removed the factory head unit there were two plugs back there, are both of those plugs plugged into the gmos-04? If so, I think the problem is the amp on the deck and the factory amp both trying to power the speakers. I think if you disconnected the smaller black plug I think the issue would go away. You gotta take the factory amp out of the loop, I've done so by simply not plugging the black plug in to anything behind the deck.
I hope that helps
Thank you for your quick response. I just tried that and the issue is the same with or without the plug.
Edit* After doing some research I think the only solution is to remove/bypass my amp. I don't know the wiring diagram and don't want to cut factory wires. Any ideas as to how to bypass without cutting factory wires?
The speakers sound fine with the factory hu. The sound is bad with actual cds (not burned) and with the radio. I ordered the AOEM-GM24 because im tired of messing with this aftermarket hu. Anyone had any luck with this module? It helps add rca cables for an amp with your factory hu
I didnt give up, I never give up! lol. I figured the gmos-04 was faulty and I got a full refund. After reading I saw only negative reviews about that module, so I decided to try the aoem-gm24. Ill let you know how it goes.
So you're still gonna run the aftermarket head unit?
