2001 SS - Speakers
Old Jul 21, 2015 | 09:41 PM
sipster19's Avatar
Default 2001 SS - Speakers
A few years ago, I replaced my front speakers with Dual Electronics 120 Watt 6.5" 3 way speakers. The specifications show that the speakers Impendance are 4 ohms. In another thread, I read that the original speakers were 2 ohms. Do I need to find a set of speakers that are 2 ohms or can I stick with 4 ohms? I have the stock amplifier in my trunk.
Old Jul 21, 2015 | 09:45 PM
From my experience as long as all the speakers are the same ohm, front and rear your gold, you won't hurt your amp.
Old Jul 21, 2015 | 10:02 PM
sipster19's Avatar
I do not know the Impendance of the rear speakers. From what I've seen, most speakers have an Impendance of 4 ohms. Is there a benefit in buying 2 ohms speakers versus using 4 ohms for the front?
Old Jul 21, 2015 | 10:16 PM
From Crutchfields site:
Depends on what kind of sound you are looking for. Generally speaking, the lower the impedance, the more power you can move through the speaker, which means more volume. A higher impedance results in better "damping" or control of the speaker movement. So the higher impedance will yield a tighter, more accurate sound, although when talking about high quality amps and subs, most people won't notice the difference.
Frosty LS1
Apr 28, 2013 11:13 AM
Tonedef
Jul 15, 2011 08:17 PM
eric618
20
Aug 24, 2005 06:00 PM
04MonteLS
Aug 13, 2005 03:14 AM
earthquake
Jan 14, 2005 06:20 PM
