02 SS seat sits too high
Old Nov 11, 2014 | 09:32 AM
VIIISecondRide's Avatar
Default 02 SS seat sits too high-FIXED
I have an 02 SS with black leather power seats. The rear part of the passenger seat seems to sit about an inch lower than the rear of the drivers seat. The drivers seat is a bit too high. There is a rectangle button on the side that seems to move the seat forward, back tilt the front up and down, and maybe tilt the rear of the seat up and down. The latter doesn't seem to happen I believe I can hear a motor noise but no movement. This is the only awkward part of driving the car. Is there actually a rear or seat adjustment (the part your butt sits)? Or is this wishful thinking?
Thanks!
Old Nov 11, 2014 | 12:13 PM
gprtech's Avatar
Yes, the rear of the seat should go up and down. If it doesn't but the motor runs, it could be the drive cable that connects the motor to the seat mechanism. It could also be something more serious, like a broken gear. The only way to tell is to pull the seat and check.
Old Nov 12, 2014 | 09:14 AM
Cool, will pull it out as soon as it gets above freezing here might be a good time to repair my bun warmers, too. I saw a good thread on that!
Old Nov 16, 2014 | 12:38 PM
I removed the seat and found a little speedo cable looking thing about four inches long, enclosed in a heavy rubber tube. The rubber tube was kinked, making the cable too short to connect in the motor. I simply pulled it out, heated the tube and straightened it out, and re-installed it. The seat works fine now. I did the passenger side with out removing the seat.
Moral of the story- don't stuff crap under the seat!
Enilced
18
Aug 5, 2011 06:19 PM
BenTheFox150
Jul 26, 2011 12:32 PM
fastback4
Dec 21, 2008 06:39 PM
Jackofnines
Apr 12, 2008 02:42 PM
spike_monte
Jul 5, 2007 07:11 PM
