01 Monte SS door speaker works intermittently
Old Sep 14, 2013 | 06:00 AM
Mr Bob's Avatar
Default 01 Monte SS door speaker works intermittently
Hello,
New to the forums. Hi everyone. I've got a problem with my 01 Monte SS. The passenger side door speaker seems to work intermittently. Most of the time if I adjust the balance controls it sounds like only the high notes are coming from that speaker. Occasionally something will happen and I'll get full sound out if it.
Is this a problem with the speaker itself or the wiring leading to the speaker?
Old Sep 14, 2013 | 06:58 AM
03SSLE's Avatar
Try cleaning the connectors that plug into the amp (located in trunk under rear deck between speakers). My '03 did this shortly after purchase and the problem went away after cleaning the connectors with electronic contact cleaner.
Old Sep 14, 2013 | 07:00 AM
Hi Mr Bob,
First, I'm not a audio expert , but it sounds like it could be a problem with a cracked wire since it is working intermittently (?). Check your wires & connections + check back to see what our Audio Tech member's suggest when they read your thread > Good Luck !
Thanks Seattle `Mike for helping our new member... I didn't see your post until after I submitted mine
bfenty
Mar 16, 2015 10:24 AM
bfenty
Apr 5, 2014 02:43 PM
Mr Bob
Sep 14, 2013 07:16 AM
silvermike19
Dec 15, 2011 05:54 PM
fastback4
Dec 25, 2006 12:42 AM
